Liked 62 Times in 29 Posts
#2 is a maybe. If you are running an LT-1 with the Optijunk setup you are allowed to run a crank trigger.
Liked 2 Times in 2 Posts
Boy things have changed from the good ole 60 and 70's
Liked 184 Times in 113 Posts
Yes and no........... Once again.
![]() You must use the Optijunk as a "distributor", the coil wire must go into it and get distributed to the 8 cylinders. You can not use individual coil packs. You can use parts of that Torque Head system, but you can only use a single external coil. You can use any ECM you like, I prefer the new Holley stuff, and no traction control devices. We have modified the Optijunk units to give us a cam sync signal for sequential fuel injection and use an external crank trigger in tandem. |
#5 | |
Is this Corbitt: Hello ! |
Liked 239 Times in 114 Posts
You might be able to run multiple coil system in Super Stock
