Old 08-14-2019, 06:27 PM   #11
Alan Nyhus
Liked 799 Times in 236 Posts
Default Re: Indy Teardown Warning
Originally Posted by Hacksaw View Post
They may not have a "spec" but they sure can scan them as well.
Agreed. But like the heads...how would they determine what's 'stock'?
"That'll never work....."
Old 08-14-2019, 07:17 PM   #12
G Schenck
Liked 81 Times in 35 Posts
Sounds like Wesley will be at Indy.
Greg
G Schenck is offline   Reply With Quote
Old 08-14-2019, 07:42 PM   #13
Jeff Teuton
Liked 325 Times in 50 Posts
I think Wesley will be at Indy.
Jeff Teuton 4022 STK
Old 08-14-2019, 07:54 PM   #14
Frank Castros
Liked 2,718 Times in 958 Posts
Moved to a new thread.
Old 08-14-2019, 08:41 PM   #15
Tom Broome
Liked 88 Times in 43 Posts
A member sent me this email below that they received from the D1 Stock Super Stock rep. I am surprised it has not been brought up sooner. This also may have something to do with the newly purchased digital scanner by NHRA. From what I here from the grape vine, they will be looking at cylinder heads with this scanner. The question I have, with the lack of tech officials and man power how did they possible get all the heads scanned, there has to be hundreds of heads used today. Shouldn't they have told Stock and Super Stock this will be the new standard. Also when scanning, do they take into account core shift. I also heard this was a major concern with the Showdown cars, maybe that's the reason for the low car count for Indy.
Interesting topic and I would like to here more opinions good or bad.
Unfortunately I had to delete the email as a request by the sender. In my opinion we should know whats going, this is why I posted it. Although I am a D1 racer I don't receive emails from the D1 rep because of my affiliation with Class Racer, draw your own consultations. NHRA has made their own announcement on this subject.
This sounds like something from the past.
At the Sportsnationals, in the late 70's, there was a sign posted on the return "road SS/AA turn here".
NHRA did not, at that time, disqualify any cars. They did learn a LOT about the cars by having them all sitting at the same place, at the same time. I expect it allowed NHRA to determine the cars that were constructed to the extremes of the rules and address technical discrepancies from there.
The FS cars that come with CNC'd heads certainly need to be held to a more finite set of standards than 60's and 70's products. I have a story about C/SM and Chev 461 heads that's too long to relate here.
Tom Broome is offline   Reply With Quote
Old 08-14-2019, 08:56 PM   #16
Markeracer
Liked 67 Times in 28 Posts
Here is a real simple scenario that could play out and potentially cover a lot of cars in a reasonable amount of time. After the last qualifying run on Wednesday park all the cars in an area near the teardown barn and ask everyone to remove their carburetors or throttle bodies. The tech officials could take one of the readily available high-quality video probes and take a look down the intake manifolds for anything that may be suspicious. Depending on the time available, the suspicious intakes could be pulled then and inspected or sealed and those cars will get an automatic invitation to teardown. It’s clear there is a new Sheriff and Deputy in town!
Markeracer is offline   Reply With Quote
Old 08-14-2019, 09:14 PM   #17
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
How will they deal with intake manifolds that have no 'spec'?
Tough to put the genie back in the bottle..... -Al
On the older cars they look at the "texture" of the cast,and run a finger in the runner.If it don't look or feel right your gone.Red Anderson(div.4) had one of those magic fingers. gsa612
Old 08-14-2019, 10:02 PM   #18
VE6DRW
VE6DRW's Avatar
Liked 43 Times in 14 Posts
Be thankful they're taking this a bit more seriously. They could solve this problem with a stroke of their pen. Imagine a rule book entry like "stock intake and exhaust valve diameter required; any other head modification allowed" and "any intake manifold or modification allowed as long as the material matches the orginal and it fits the stock carb".
I think more races are won and lost on the drag strip than in the teardown barn.
VE6DRW is online now   Reply With Quote
Old 08-15-2019, 05:27 AM   #19
james schaechter
Liked 1,428 Times in 296 Posts
Wow you really don’t understand class racing...
James Schaechter 3163 STK
Old 08-15-2019, 08:19 AM   #20
Mike Fuller
Liked 198 Times in 79 Posts
From what I have been told NHRA is trying to bring things back under control based on a incident that happened in the recent past. Wesley will lead in this endeavor.
Mike Fuller 396 STK
3961 SS
