Old 08-07-2019, 08:07 AM   #11
Jesse Kershaw
Liked 122 Times in 11 Posts
Default Re: Digitizing Cylinder Heads Help
when we were working on the D3 heads for the 429 combination I had a NASCAR head "scanned" by the Ford lab. They gave us a solid model file that even included the coolant passages inside the head. I'm not sure how they did it. Converting it to something usable in a CNC took some doing though.
I know for larger items the scan is different and they applied a white powder. We did this with Morgan's prostock car at one point.
If you're looking for something late model it's possible the OEM has data or might be willing to help you with a scan.
Jesse Kershaw
Jesse Kershaw is offline   Reply With Quote
Old 08-07-2019, 10:16 AM   #12
SSDiv6
Liked 1,607 Times in 584 Posts
Jesse,
Most of the OEM's and big aerospace companies either use the Renishaw Cyclone digitizer or the Nikon Laser scanner. You can basically reverse engineer anything with those scanners.
Old 08-07-2019, 01:51 PM   #13
Jim D'Amore
Sponsor
Jim D'Amore's Avatar
Liked 66 Times in 17 Posts
Jesse,
Well I guess NHRA is a big company now, they purchased a $60,000 scanner to use on showdown cars and stock eliminator cars. I received a phone call from Ford Performance letting me know that NHRA scanned cylinder heads for the Ford showdown cars. For six weeks all Ford show down cars were illegal. They just reversed that rule and said show down cars will have designated cylinder heads starting 2020. So with show down cars out of the way my guess would be they are going to focus on Stock Eliminator cars at Indy. It is no longer just runner volume, cylinder heads have to match all OEM and Aftermarket (ie Edelbrock) After 50+ years there is a new sheriff in town.
Jim D'Amore
Jim D'Amore is offline   Reply With Quote
Old 02-16-2025, 12:55 PM   #14
Stan Weiss
Stan Weiss's Avatar
Liked 735 Times in 386 Posts
Jim D'Amore
I know. Very Very old thread. Does anyone know what happened to this?
Stan
PS - Took awhile for the memory to work lol There was another thread somewhat like this a few years later which I had made a post in. But that had no real answer either.
Originally Posted by Stan Weiss View Post
Wasn't there a rumor a few years ago that NHRA bought faro arm to check heads?
Stan
Last edited by Stan Weiss; 02-16-2025 at 01:25 PM. Reason: Added quote from another thread
Old 02-16-2025, 04:06 PM   #15
Dan Bennett
Liked 609 Times in 140 Posts
This brings back memories of too much too soon. In 1996 through conversations I had with Jere Stahl, the pro stock team I was working with decided to go this route.
The only person we could find that was even slightly interested was a wheel maker (of all people) who had just bought a 5 axis and was willing to try but not sure if it could be done. "I need to make chips 24/7" was what was his motivation.
The plan was to digitize the best port(s) on the best handground heads we had and use that as the program for all ports on a new head. The plan failed because the inhouse engine builder was very protective of his position and status and threw wrenches into the plan anytime he could.
And looking back along with knowing what we now know, that plan was probably flawed. I have the impression that even with the most precise standarization that could be done, different cylinders are going to want different things.
So many things have changed for the better. I can't tell you how many times both the head builder and the manifold constructor would say variations of "I wasn't in the mood" or "I just haven't been feeling it" when contacted about long delays in delivery of what they'd already been paid for.
Dan Bennett is offline   Reply With Quote
Old 02-16-2025, 04:22 PM   #16
SSDiv6
The current digitizing equipment available nowadays would blow your mind!
I purchased for use by my Inspectors, a laser-based CMM made by Keyence, that will measure parts in seconds based on a reference CAD file; no calipers or other measuring devices are required.
We also have a Keyence hand-held, laser-based scanner that will measure parts and create a CAD file.
Old 02-16-2025, 05:56 PM   #17
When NHRA decided to do that, they, a tech inspector, and a couple of engine builders got sued.
Some people vehemently defend their cheating, and NHRA doesn't want the hassle of all of it.
Old 02-16-2025, 06:23 PM   #18
BRETV
Liked 778 Times in 200 Posts
Maybe the new IHRA could implement these techniques during teardown and enforce the rules like they should be. Then winning an Ironman would mean more than winning a Wally. Just an idea.
Bret Velde
2003 I/SA
BRETV is online now   Reply With Quote
Old 02-16-2025, 07:25 PM   #19
SBillinson
Liked 183 Times in 48 Posts
Joe,
I have a digitizer similar to a renishaw but only 3-axis, which limits port digitizing, especially at the short turn and bore wall side.
I looked at Keyence, but am unclear about which product would work best for port digitizing. Laser, I assume, would provide the best detail, but at what cost?
Having a digitizer that has file extensions compatible with CFD software would be ideal (like Autodesk CFD, not Siemens or something only OEMs can afford). I'm sure it exists, but, again, how much?
Thoughts?
Hope all is well.
SS/BS 1921
SBillinson is offline   Reply With Quote
Old 02-16-2025, 08:21 PM   #20
Stan Weiss
Stan Weiss's Avatar
Bret Velde
2003 I/SA
Bret
Does anyone have a WAG of how many / what % of the cars have illegal heads. If this number is high enough I don't see the IHRA doing this. Most people will not build another engine to run IHRA. I don't see the IHRA making a rule which would limit car counts.
Stan
