Liked 21 Times in 13 Posts
I don't see anything in the rule book on this, but in the accepted products document there's a section called carb notes, and it says it's ok. Although the way the documents reads, it's not super clear what it applies to.
Brian Carpenter Stock 1358 |
Liked 56 Times in 31 Posts
The choke plate has to stay, but can be open and inoperative.
Thomas NHRA 1959 D/SA |
Liked 783 Times in 195 Posts
Carb notes apply to carburetors used in Comp and SS/Modified, not regular Super Stock or Stock.
page 62 does mention Stock, SS, etc. But the context is replacement carbs, so probably doesn't include alternate carbs..........
Liked 272 Times in 108 Posts
Take it off and put it back on if they tell you to.
Liked 10 Times in 6 Posts
Just be sure you keep the choke plate and shaft in the tool box in your trailer because you will have to put it back on someday.
10-4
Liked 320 Times in 102 Posts
In tear down, if I was a Tech guy and found a car running without the choke plate, my recommendation would be for a 1 year suspension due to an intentional violation of the rules.
Liked 5,146 Times in 1,964 Posts
I doubt if found during a spot check after winning a 3rd round heads-up, that they would allow you to put it back on.
As Bob said,...maybe in a year or so.
So I get where the rule book does not allow removing the choke. The reason I started this thread is because it looks to me if you are allowed a "replacement" carb, i.e. edelbrock, or quickfuel, which seems to be legal in stock, it spells out in the carb notes what mods you can do, and that includes removing the choke. That doesn't make sense to me, but that is what I see. Maybe I'm reading it wrong.
