Old 06-29-2019, 04:54 PM   #1
Mark Ugrich
Liked 71 Times in 38 Posts
Default Re: Cleaning steering wheels ?
Try some tire cleaner. I use it to clean interior panels and plastic trim. Works great.
Old 06-29-2019, 06:40 PM   #2
2021STK
Liked 17 Times in 14 Posts
Having the same issues, would like to hear someones success story and product used.
Thanks
Dave Outten
2222 S/SS/SST/SG/HR
2021 S 1968 SS 1969 SR 1966 1990 Bracket
2021STK is offline   Reply With Quote
Old 06-29-2019, 09:28 PM   #3
KRatcliff
Liked 534 Times in 143 Posts
Not sure this will work, but it may be worth a try. Dawn dishwashing soap does wonders sometimes. You might also try the Armor All interior cleaning wipes. The leather steering wheels on my street cars and trucks will get sticky/tacky over time. I tried everything and nothing worked right.
I don’t know what possessed me to try the Armor All cleaning wipes because I thought they would be the last thing that would work. I was shocked. The steering wheels feel like a smooth dry non-tacky leather like they did when the cars were new. It is after they dry from the wipes and you will see how filthy the steering wheel gets.
KRatcliff is offline   Reply With Quote
Old 06-29-2019, 10:47 PM   #4
FED 387
Liked 335 Times in 182 Posts
might try lacquer thinner
Old 06-29-2019, 10:58 PM   #5
stage1scott
stage1scott's Avatar
Liked 109 Times in 44 Posts
I used many of them in my old blazers and suburbans-get some go-to cleaner from California Car Cover-wet a terry cloth towel- soak the wheel in gtc, twist vigorously around the rim with the towel. I used to use 409 for this back in the day, Go To Cleaner works better. it is easier if it is mounted to something.
Old 06-30-2019, 12:38 PM   #6
Dave Gantz
Liked 251 Times in 125 Posts
Might wanna be careful with lacquer thinner. Pretty aggressive. Maybe prepsolv.
I've used super clean or purple clean, whatever it's called. Aggressive degreaser that seems to be soap based. Lots of water needed to clean the purple stuff off, it's sticky in itself.
Old 07-02-2019, 04:51 PM   #7
Todd Bailey
Liked 33 Times in 17 Posts
I JUST cleaned one this past February and actually used carb cleaner from Walmart. Theirs is not as potent as say the Gumout brand. You WILL turn a lot of paper towels yellow in the process to get the oil, residue,whatever, etc from the wheel. After cleaning it, i sprayed it with WD-40 and wiped it down. It presently is in the '69 Camaro Stocker ragtop that the Emmons have.(Pops's former car)
Todd Bailey is offline   Reply With Quote
Old 07-02-2019, 06:04 PM   #8
Jeff Kempton
Jeff Kempton's Avatar
Liked 69 Times in 33 Posts
I've cleaned them easily in the past using hardware store paint thinner. There's another thread currently on FB where someone suggested dusting it with baby powder after cleaning to seal the pores, which seems like a good idea.
Jeff Kempton is offline   Reply With Quote
