Old 05-28-2019, 04:30 PM   #1
Eric Voigt
Liked 18 Times in 11 Posts
Default Re: MOPAR BB 727 Trans Shield
I just called and talked with the "tech" line informed them my application was BB 69 B-Body. He informed me that I "might have to roll the body seam line at the floor" some to make it fit. Also, remove the casting tabs at the front as well and what ever I do NOT trim the shield in any manor as they will not "re-certify" the shield as any modification removes them from any liability.
They did state it was designed off a "dragster" application. Why not design around the tightest application first? Oh the joys.....
Eric Voigt 7425 STK
Eric Voigt is online now   Reply With Quote
Old 05-28-2019, 06:36 PM   #2
Rod Greene
Liked 242 Times in 81 Posts
Ollie put a stick in it...............lol
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 05-28-2019, 08:48 PM   #3
Steve Stasko
Liked 292 Times in 147 Posts
You may consider the Robin Hood blanket. Supposedly it's quite pricey though.
https://robinhoodblankets.com/2017/12/28/rhb-photos/
Old 05-29-2019, 09:16 AM   #4
John Dinkel
Liked 265 Times in 69 Posts
Racerdirect.net SFI 4.1 RDN22000901 Blanket About $95.00
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 06-02-2019, 03:27 PM   #5
Deeznuts
Just bite the bullet and put the CSR in and modify the floor as needed. It shouldn't be too much. Your Charger has alot more room than an A body or an E body. Since you are going to drive it on the street too I would stay away from the blanket, they just get messy dirty in a street application.
Jimbo
Deeznuts is offline   Reply With Quote
