Old 05-27-2019, 08:08 PM   #1
jrstock
Default Rear Main Seal Advice
I have observed a leak from my rear main seal. The leak is occurring ,not at the seal split line, but at the bottom 6 o'clock position. Currently using a Fel Pro 2090 seal.
I've pulled the seal and it does not look worn or damaged.
Is there a way to shim between the seal to tighten the clearance to the crank? Is there a better SBC main seal to use?
Is there a tool to locate the 2pc rear main seal adaptor on the crank that I should be using?
Any other tricks to stop the leak?
Thanks in advance for the advice.
jrstock is offline   Reply With Quote
