Liked 648 Times in 140 Posts
I was curious to know if any of you using the Grid would share your experiences. Is it easy to install and use? They say it can be used with several of their ignitions? Is there a reason to use the digital 7 instead of the 7AL? Do you need to use a dual sync distributor? What if anything did you see as a performance gain? Can you store multiple timing curves to switch back and forth? What am I not asking that I should be? Thanks, Mike McMahan 2543 H/SA
