Old 05-12-2019, 12:51 AM   #1
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Default Re: Brakes help
Okay. First step is take the pedal out and drill a hole about an inch up. They are case hardened , so use a drill press.
That's the free one , before getting out the Plasti-Card.
Umm, If it is actually Case Hardened, A solid carbide drill bit is not going through it. I like the welding in an extra 2", that will give more leverage but will put the pedal close to the floor.
My car has 2 stubs welded on the brake pedal lever from the factory. I also put as large of a Rear wheel cylinder I could find on the Fronts. (4 wheel drums)
Dave Noll, EF/S ,?/SA 6526
Old 05-12-2019, 02:30 AM   #2
Liked 5,151 Times in 1,966 Posts
Maybe not the correct term, but definitely hardened ..You could see it on the metal.
It creaked and groaned and smoked , but it went, on a good size drill press . Kinda like drilling a center bolt into mono leaf springs..Ahnold probably could have done it a little easier.
Old 05-12-2019, 09:21 AM   #3
Alan Nyhus
Liked 800 Times in 237 Posts
Case hardening only hardens the surface. The material under the hardened surface remains unaltered. -Al
"That'll never work....."
Old 05-12-2019, 10:13 AM   #4
jerry witzel
jerry witzel's Avatar
Liked 44 Times in 15 Posts
Here's an adapter for the master cylinder. https://www.ebay.com/itm/Pro-5-0-79-...wAAOSw7cZcM86v
Old 05-12-2019, 10:30 AM   #5
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
For what it's worth I changed the pedal ratio and wound up never installing the proportioning valve that I bought. If anything the pedal is a little soft, but I can get over 1000 PSI easily in one shot and it holds fine on the line (as long as the 2-step in on...).
It took a could of tries to find the right bore size for the master cylinder but it was worth taking the time to work it out. I wound up with 1 1/8 inch.
Dave Muller is offline   Reply With Quote
Old 05-12-2019, 01:00 PM   #6
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
I have one of these already
U/SA
79 Mustang
Old 05-12-2019, 11:30 AM   #7
Makes sense. Might be then. Once you get the drill bit started, it'll go.
I'm sure the pedal arm is hardened for safety reasons.
Old 05-12-2019, 03:02 PM   #8
Dave Noll
Dave Noll's Avatar
Machining through a 60Rc surface can be done, but not easily at all.
Speeds and Feeds
SFM IPM DOC (Inch Depth of Cut)
Carbon And Alloy
Steels (50-60 Rc) 300-500 0.002-0.008 0.003-0.020
Die Steels (55-65 Rc) 150-350 0.002-0.008 0.003-0.008
Old 05-12-2019, 01:03 PM   #9
RobbieRacer
Mine only has one stub and it's also welded on.
U/SA
79 Mustang
