Old 05-11-2019, 06:08 PM   #1
Billy Nees
Liked 7,775 Times in 1,742 Posts
Default Re: Brakes help
Okay. First step is take the pedal out and drill a hole about an inch up. They are case hardened , so use a drill press.
That's the free one , before getting out the Plasti-Card.
Also, raise up the master cylinder the same amount.
It might help you to look up my old "Under the Index for Under a Grand" thread. I posted some pics on there of how I took off the booster and modified the pedal.
Billy Nees 1188 STK, SS
Old 05-11-2019, 07:58 PM   #2
The factory power eliminator aluminum piece raised it up some, too. Very rare!
Old 05-11-2019, 10:06 PM   #3
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
Thanks Mark and Billy. I never thought to raise the master cylinder. I can do that. Would making the pedal 2 inch longer do the same thing? More leverage.
U/SA
79 Mustang
Old 05-12-2019, 12:10 AM   #4
Rory McNeil
Liked 1,104 Times in 302 Posts
The best bet would be if you could find a complete manual brake setup from a low option early FOX Mustang, Fairmont etc. That way you get the correct manual brake pedal, the aluminum master cylinder firewall mounting bracket, and master cylinder. As Mike Graham mentioned, the manual brake pedal pedal location on the pedal bracket is also different, but both holes are drilled, so simple to move the pedal pivot location. Not sure what the caliper bore size on your larger front disc brakes are, but that could potentially be a problem. My 85 Mustang started life as a 4 cylinder car, and I retained the small factory front disc brakes, and stock rear brakes from the 5.0 doner Mustang, and swapped all the factory manual brake pedal, master , and bracket from a stripper junkyard Mustang. Had no problems stopping the car from 107 MPH, and even with the much stronger bracket engine, going 128 MPH, the stock, small brakes worked pretty good.
NHRA 6390 STK
M/S 85 Mustang
