Liked 12 Times in 8 Posts
I will call you
Duane |
Liked 72 Times in 36 Posts
We had a shifting problem like that and the problem was we were a little low on Fluid. We added fluid and put the car on jack stands and ran the car thru the gears and that fixed the problem. I hope that will fix your problem also.
Kenney Kelley Last edited by Kenney Kelley; 05-06-2019 at 12:44 AM. |
How much are you "leading" your shifts? Some computers, and some transmissions are slower than others. I have found very few set ups that will actually get the shifts in fewer than 400 RPM above the shift RPM you enter.
Often the RPM difference won't be the same for the 1-2 shift and 2-3 shift. RPMs climb much faster in low gear, than second, so we have to use more lead for the 1-2 shift. To shift a T350 at 7800, I have had to use 7300, then 7400, to get the shifts done @ 7800. Most I have delt with prefer the 1-2 shift to actually happen at a lower RPM than the 2-3 shift. Guessing everybody knew that last part. My stick cars always liked that lower 1-2 shifts RPM too. I hope some of this helps. A quart low on fluid will make mine do it too. Rev limiters set too close to the shift RPM will cause that too.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 05-06-2019 at 03:06 PM. |
Liked 171 Times in 36 Posts
Check your grounds for the e-shift controller. Had similar problems a few years ago and it turned out the grounds just weren't good enough. Ended up running a heavy ground wire for the e-shift controller to the main chassis ground to correct the issue.
Hope this helps. |
#5 | |
Liked 239 Times in 114 Posts
Liked 140 Times in 51 Posts
Had a couple problems with solenoids over the years but I think they have changed to a different type.
The more people I meet the more I like my dog Kevin |
