Old 04-10-2019, 05:08 PM   #1
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Heads up
* Normally shift at a lower RPM, then shift at the optimum RPM during heads-up race.
* Swap out your normal oil for a lower viscosity. i.e.: normal 10w-30 conventional oil, heads-up 5w-20 or less special conventional or synthetic.(Consult your engine builder.)
* Rear end can usually have a quart or a bit more drained below normal capacity.
* Advance/optimize timing if running conservative.
* Make sure your jetting is optimized without a filter if removing it. Otherwise, removing the filter may lean out the carb if the filter has any restriction
* Add air to rear tires, IF it will hook with a smaller contact patch.
* If cutting weight close to minimum, remember to weigh EXACTLY what you take out and include the weight of any oil drained. Keep a little safety margin.
* Adding air to front tires will help minimize rolling resistance too, but it can also reduce rollout and quicken RTs. (Don't redlight.)
* Switching from same size bias ply slicks to radial slicks usually helps pick up ET as well as RT. But finish line RPMs will be a bit higher because radials don't grow like bias ply. (As long as your engine can handle it.)
Just remember that you have to be able to return to a predictable dial-in afterwards for the next run if you win the heads-up race.
LOCOMOTION Racing
Old 04-10-2019, 06:12 PM   #2
Jeff Stout
Liked 706 Times in 283 Posts
Default Re: Heads up
^^^ This. We had a street car event and in the final round we needed a little bit more as it was heads up. I said take the air filter off and then proceed to run .1 slower in ET. and lost the race. Then realized car went lean with filter off. Ooops
Old 04-10-2019, 07:55 PM   #3
jimmyparker
Liked 309 Times in 88 Posts
Some of you may remember Don Carter from South Carolina who ran C/SA in the nineties with a red 69 Nova, one way to remember him is he looked like one of the Oak Ridge boys. Anyway Don had a headsup first round at the GV divisional in that period with some one who had him covered a bunch. I asked him in staging if he had a plan and he stated he was going to pray, the faster car broke in the water.
jimmyparker is offline   Reply With Quote
Old 04-10-2019, 08:10 PM   #4
jmoneyfoot
Liked 9 Times in 5 Posts
How does engine temp play a factor? I see everyone putting ice on the intake and fuel regulator, pushing their cars through staging. What is an optimal engine temp?
jmoneyfoot is offline   Reply With Quote
Old 04-10-2019, 08:55 PM   #5
MR DERBY CITY
Liked 8,206 Times in 1,536 Posts
Many, many years ago Lee Bannister was kicking Azz and taking names in stock eliminator. Lee usually qualified near the bottom of the ladder and one year at the Gators he had a heads up with a much faster car. The faster car just blowed the tires off at the hit.....Lee must know the same prayer....
