Old 04-01-2019, 07:52 PM   #1
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Cable or rod
from carb to pedal and stock or aftermarket gas pedal assembly in your S/ST car.
Photos either here or PM if you're willing to share. Thanks in advance.
Old 04-02-2019, 09:45 AM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: Cable or rod
Advantages to both, much depends on the type of throttle stop being used.
An inline throttle stop will work as well as any under carb stop when using a cable .
Most cars ,even with engine limiters still have too much engine movement to be precise
using an inline stop with a rod setup.
Biggest issue with a cable is space . The flimsy stock type or Lokar cables really aren't suited for the abuse of racing .
I've always used Morse cables on cars I've built that utilized a cable ,but they can be a bit of a space problem under the dash of some door cars, plus using an inline stop with a cable will almost always necessitate mounting the carb backwards.
With an under carb stop ,I would always build with rod linkage.
Old 04-02-2019, 12:42 PM   #3
1320racer
1320racer's Avatar
Tom, thanks for your reply. Check your PM, thanks
Old 04-03-2019, 01:49 PM   #4
Ken MacNicol
Ken MacNicol's Avatar
Liked 26 Times in 12 Posts
Cable with stock pedal and under carb stop.
Ken MacNicol is offline   Reply With Quote
Old 04-03-2019, 03:49 PM   #5
1320racer
1320racer's Avatar
that is my current set up.
