Go Back   CLASS RACER FORUM > Stock/Super Stock Associations > IHRA Pure Stock Challenge
Old 03-28-2019, 02:29 AM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Pure Stock ET Mph
November 2018 Mason Dixon S/SS Race; best 12.58 107
Ran heavy near full tank at 4150 lbs
March 2019 ECIRS Meet ran best 12.470 at 106.73
There was a little more left could have hit 12.45...
Weight around 4150 lb...had to add 5 gallons C9
That is 1.28 under the F/PS index of 13.75.
Going to add Roll Bar, 5.13 gears. Rear gets C-Clip’s eliminated.
Remove mufflers, should run closer to K/SA index in heat.
Ran a lot of 12.85’s, managed a 12.72 at Atco on a good Summer day.
Figure a tenth in block with a Index crank, upgraded rods and pistons.
Figure a bit more with an proper 8 inch converter..
Corbitt Marshburn’s got his 96 Impala SS in F/PS trim to 12.39.
To go quicker would have to REM and Micro Coat all the bearings.
Be interesting to see how far the car will go with the Bullet Blueprint Cam.
Adding the Stocker cam will be interesting.
All that is need is time to get this stuff done..
Old 03-29-2019, 11:56 AM   #2
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
Default Re: Pure Stock ET Mph
Good luck Dan.
Mitch Beri- The Motor City
