Old 03-04-2019, 08:56 PM   #34
J&S Racing
Liked 319 Times in 82 Posts
Default Re: 69 Camaro B/S
Thanks guys!!
[QUOTE=gmonde;583884]did you replace your stock linkage with heim joints from the pedal to the fork ? that's an upgrade worth doing
as mentioned .050 is a good place to start ,also TOB to levers should be no less than a 1/4 as for the amount of counter weight will affect how close the fingers comes to the bearing at high rpm,,
gmonde
I am replacing the linkage. Think I need to take about 3” out of the top bar but it’s getting there.
