Old 02-18-2019, 05:23 AM   #4
Adger Smith
Liked 880 Times in 311 Posts
Default Re: BBC 454 block
Larry,
The Gen 6 blocks are a lite by quite a bit, but pans, covers and lifters are different. Then the 2 piece rear seal adapter or 1 piece crank.
I assume this is just for your bracket ride.. I have a Std 4 bolt Mark IV I have Decked, align hone and ARP main studs, no fill.. Might make std on some hi limit pistons. I will check it in the morning.
I also have a short deck Gen 6 Marine. Siamese cyl. 4.53 bore, 9.780 deck, align honed w/2 piece seal adapter fitted and installed. No filler.
All machine work is fresh on both ^^^..
I have a couple new Merlins and a Brodix in stock.
You know I've got a shop full of good stuff.
Call me.
Adger Smith (Former SS)
