Old 02-15-2019, 06:13 PM   #1
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Default Re: 2 step off brake pressure switch ?
Originally Posted by black88coupe View Post
Sounds like it would be slow to react hooked up like that.
Why do you say that???
Electricity travels at about 300,000,000 meters per second...
Bob Mulry 7516 STK
A & M Motorsports
Old 02-16-2019, 09:22 AM   #2
Coleydog
Liked 53 Times in 38 Posts
Just thinkng out loud, why would activating a two-step at the finish line be a problem? You have already let off the gas and most race converters stall at 4500 and above so if the 2-step activates at say 3500, wouldn't the engine just freewheel?
Besides on another note, if your shifter allows going to reverse by accident at the finish line, you need a better shifter. My hand is on the handle ready to neutral before the line, then I brake.
Mike
Old 02-16-2019, 11:35 AM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Mike
It isn't normal slowing that's an issue. ...It's a problem because if you stab the brakes at the stripe to tighten it up or give it back , the 2 step instantly pulling the engine to 3 or 4000 rpm is akin to using a Jake brake on a diesel truck .
Especially on a car with steep rear gears .
Old 02-16-2019, 03:56 PM   #4
Coleydog
I had a very loose converter that allowed the engine to flutter at 7000 on the rev limiter, (drive shaft was 5600) it just drops ignition on various cylinders, not closing off the exhaust like a jack brake. I'll try it out this spring to see what happens, intriguing. some type of cut out switch would be the best.
Old 02-16-2019, 11:03 AM   #5
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
Im referring to the hydraulic pressure in the brake line taking longer to release the switch when you take your foot off the pedal. How would that action be equal too or faster than using say a transbrake switch on your shifter? The action from using a transbrake switch seems like it would be much quicker. Is there something im missing here? Thanks
Mitch Beri- The Motor City
Old 02-16-2019, 11:29 AM   #6
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
The shifter mounted switch won’t pass tech in Stock.
Dave Turner
SS/GT #1153
Old 02-16-2019, 11:30 AM   #7
black88coupe
Gotcha! Thanks
Old 02-18-2019, 12:52 AM   #8
Eman
Liked 133 Times in 76 Posts
Probably is, but if you're not allowed a transbrake this is a way to leave at the same RPM every time footbraking.
I tend to scrub the brakes before the stripe to tighten it up, doing this with my foot on the throttle. If I didn't have a way to shut the 2 step off it would stutter at the top end. I have a switch that controls the power to the brake pressure switch and a small LED on the dash to show when the brake pressure activates the 2 step so I know I'm on the brake hard enough at the starting line.
I've thought about using a high gear pressure switch on the trans that would open the power circuit in high gear.
Old 02-18-2019, 07:54 AM   #9
black88coupe
Sounds pretty ingenious.
Old 02-18-2019, 11:03 AM   #10
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
And there I thought I was the only one to use an LED like that!
Dave Muller is offline   Reply With Quote
