Liked 19 Times in 17 Posts
Installing disc on front of 66 Chevy2 with drums on rear. Brake tech stated I needed 1 1/16" mc bore and 10lb residue valve for rears. I seem to remember there was a Chevy Al mc with 1 1/16" bore, but can't remember all details. Hoping someone can help my memory out. Thanks.
Ed SS2266 |
Liked 239 Times in 114 Posts
I got one from a early 80's S-10 pickup It had a flatter plastic tank on top .
Liked 314 Times in 177 Posts
Don't think anyone made an aluminium master cylinder that looks "stockish". I'm going to try a stock master from a 69 Nova on my Chevy II with the distribution block and prop. valve attached on the brackets that bolt to the mounting of the master. Won't know how it works out till next summer.
Liked 15 Times in 11 Posts
Ed, is this a drag race car and is the MC mounted in stock location?
Liked 133 Times in 76 Posts
Is this for a manual brake set up? For an aluminum GM master cylinder I'd look at an S-10 with manual brakes. I've used a GM MC from an early 80's fullsize pickup before but they are cast iron. Most GM aluminum master cylinders were made for power assist and the problem with them is they are made to mount at an angle, the resevoir is the problem.
I wouldn't worry about a residual ck valve unless the MC is lower than the brakes. |
Liked 427 Times in 97 Posts
NAPA part number M2456, This might be a bolt in for what you are doing
Liked 169 Times in 53 Posts
The s-10 one is the way to go. bolts right up, is level and has enough volume to work with disc brake setup.
Bill Bogues 4696 STK |
#9 | |
Guest
Posts: n/a
#10 | |
