Old 11-29-2018, 06:38 PM   #9
1legjerry
Liked 72 Times in 15 Posts
Default Re: 1 battery or 2, 12V
Battery cables should also be changed out every 5-10 years also. It is getting hard to find good wire and it will go bad. You should also check the terminals on the cables too make sure they are tight. I would suggest doing a voltage drop test on your starter/battery circuits a couple of times a year. It should also be the first thing you do when you are having a starting issue.
1legjerry is offline   Reply With Quote
