#21 | |
Liked 373 Times in 131 Posts
Only the 83 GT had a scoop. The other V-8 Mustangs in '83 got a flat hood ( GL, GLX, etc. )
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#22 | |
The CFI has 2 injectors. Not a problem, just run a couple of 100 ponders. The problem is the tiny 2 blade throttle body. I never measured but it looks smaller than a 350 cfm carb
#23 |
Since it seems this guy "has" to have a V8 and automatic, the obvious thing to do is to convert the nose piece and taillights, and run the car as a 79 302 2 barrel combo. Since NHRA gave the 302 2 barrels a drastic HP reduction a few years ago, there have been more and more showing up, often near the top of the qualifying sheets. The 82 only 302 2 barrel "High Output" Mustang/Capri combo looks pretty good too (Bigger cam and carb), but you have to run "That Scary" manual transmission with that package!
As for the 88 TBird, not sure if the engine combo is much different, but there is a 86 TBird 302 in Div. 7 that has been running for several years .
#24 |
Liked 7 Times in 6 Posts
#25 | |
Liked 32 Times in 14 Posts
As for the 2 bbl 302, sounds interesting. The 87 Tbird uses the same 302 HO as the 87-93 Mustangs according to NHRA specs. I'm very familiar with that combination in a Mustang. Even have some parts leftover. just trying to give him the best options available to hopefully get him into a Stocker.
Jay Roeder facebook.com/racefuelsales Former N/SA , Soon to be SS/AS, Renegade Race Fuel dealer |
#26 |
Yes, the CFI didn't look very good to me.
#27 |
Does anyone run a 87-88 Tbird with the 302? Haven't come across anyone.
#28 | |
Same combo as the Mustang but with more frontal area of the car to push wind. A foot longer in length as well and takes up more space in the trailer. Seems the 87-93 Mustang would be a better choice. I don't see where the T-Bird would have an advantage. The big disadvantage to the Fox T-Bird is racing suspension parts are harder to find ( upper and lower rear control arms are different than a Mustang) I ended up taking Mustang parts and cutting them up and lengthen them to fit. It's just more economical to build a Fox Mustang especially since the used parts market is flooded with parts
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT Last edited by ALMACK; 09-26-2018 at 11:48 AM. |
#29 | |
#30 | |
