Liked 1,954 Times in 491 Posts
Is this a lot? 33 spline 12 bolt.
Todd Greene |
I know people who had axles "rifle drilled" to lighten them, and saw zero E.T. changes.
Un-sprung weight is not as desirable as weight suspended, or "sprung-weight", I am told. Weight changes on larger diameter components would be more noticeable due to effects on inertia. Lighter axles, as I have been told, "can't hurt a thing." I have some very bright friends. Wish I knew everything they know.
Ed Wright 4156 SS/JA |
These things just seem awful heavy, I may have to call an axle company tomorrow to check weights.
Todd Greene |
Liked 7,909 Times in 1,513 Posts
When you are running a stick shift, Sooner or Later.....You will purchase Mark Williams axles....They weigh what they weigh.....
Liked 346 Times in 126 Posts
Liked 330 Times in 178 Posts
Rifle drilling and scalloped flanges will result in a 17-25% weight reduction over a non lightened axle--- also keep in mind that a one pound reduction in axle weight is like a 15-17 pound weight reduction that the engine sees it has to try to overcome--FED 387
Thanks for the replies guys. I did call Strange today and in order for them to get me a side by side comparison they need the length of my axle, I'll get it and try to call back tomorrow.
Todd Greene |
Liked 254 Times in 78 Posts
Sounds like quite a bit, curious how you arrive at those amounts?
Mike Moller NHRA 203 Q-R-T/SA |
#9 | |
https://www.markwilliams.com/aerp3.html
Todd Greene |
A cubic inch of steel weighs .283 pounds plus add in all the material in the flange multiply that by 2 and you get a number probably about 4-6pounds per side depending on axle length and diameter
