Old 05-05-2018, 08:23 AM   #1
MR DERBY CITY
Liked 8,209 Times in 1,536 Posts
Default Re: Willwood, Strange or Aerospace?
[QUOTE=Ed Wright;562398]
Might be the installer, not the parts. Excessive pedal travel, ask and competent automotive technician, is caliper/rotor alignment/cylinder sizing. Too small master cylinder bore = excessive pedal travel. Caliper not square with the rotor = excessive pedal travel. DIY guys usually need a dummy proof install pkg. My car stops great, with no excessive pedal travel. Has for about 8 years now.
The same installer, Bob Gullet,...installed the LAMB brakes with far greater results. I believe Mark Markow sums it up best....
Old 05-05-2018, 09:50 AM   #2
Ed Wright
Ed Wright's Avatar
Pedal travel is not the brand. SMH
Simple hydraulics. Some seem to need a simple take it all out of a box & bolt it on kit.
Ed Wright 4156 SS/JA
Old 05-05-2018, 02:31 PM   #3
CMcAllister
Liked 925 Times in 263 Posts
It should be a simple calculation of piston area and master cylinder bore. But I've seen more than one car with Aerospace kits that should have worked, but didn't. Could not get a pedal, even with a big bore master, until a Lamb master was installed.
And I've seen guys get kits from Wilwood with calipers that had small bores for some reason (ordered wrong part# maybe) and the balance would be all out of whack. Strange has always been plug and play.
Old 05-05-2018, 09:10 PM   #4
Ed Wright
Ed Wright's Avatar
Installed mine back in 2010, before I closed my shop. I don't know what another brand could do, that these do not. No pedal is not the brand. Wrong pedal ratio, or master cylinder bore. I was warned once about "smoking all 4 tires at the finish line." Didn't realize I locked them up. Wheels roll freely, good pedal, plenty of breaking power.
What else is there?
Maybe they changed something.
