Old 05-04-2018, 10:28 AM   #1
brian schuetta
Liked 28 Times in 15 Posts
Default Re: 1986 tpi 350
The 87' s were center bolt valve covers with a roller cam?
brian schuetta is offline   Reply With Quote
Old 05-04-2018, 07:36 PM   #2
killintime6968
Liked 91 Times in 29 Posts
Yes 1987 had roller cams and center bolt covers.
Bruce Cameron
68 Nova 396 E/S
68 Camaro SS/? ex Checkmate Modified
killintime6968 is offline   Reply With Quote
Old 05-08-2018, 02:48 PM   #3
brian schuetta
Got the whole thing tore down, yes it was rebuilt. Two bolt block, one - piece rear seal, .060 over hyper pistons. The 261? heads are 1.72/1.5 valved with large chambers, totally useless except for shop cores. I plan to sell the TPI setup, manifold, runners, plenum, throttle body, and fuel rails. Those parts are from an 85-87 F-body. The bottom end will be cleaned up with new bearings/rings and sold either like that or running with different heads. I'm keeping the exhaust manifolds with the air tubes and connected lines for that system.
