Old 03-14-2018, 12:28 PM   #11
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: Stocker Roll Bar
[QUOTE=ALMACK;558172]Dan:
here are the pics of the 09 Mustang.
Because the seat back did not lean back to it's normal position, I had to "flip" the head rests...otherwise with a helmet on there's no way I'd be comfortable. I may still cut the cross bar out and install a 2" setback version
Also, I think it may be tough to make it easy to sit in the back seat by following the current rules regarding roll bars. I tried to crawl under mine. Going over would be easier if I needed to.
I do like the fact that I can remove any of my seats easily
Looks really nice.
Like that my cars has 4 Doors..
Changing over to Stock is a pain..!
A Roll Bar is a wise safety item to add anyway.
Adding the last changes planned, document the results.
Will get the car closer to the 12.65 K/SA index.
Typically a 13.15/12.95 car during the season, figure 2 tenths left.
Cold day looking to hit a 12.45, best to date is a 12.65 at Cecil.
A new Stocker Cam should get the car to run 3 tenths under consistently.
BUT first the Roll Bar !
D
Old 03-14-2018, 12:44 PM   #12
ALMACK
ALMACK's Avatar
Liked 369 Times in 127 Posts
[QUOTE=Dan Fahey;558178]
Originally Posted by ALMACK View Post
Dan:
Looks really nice.
D
I forgot you have a 4 door.
Plus you have a body on frame car so it might be harder than a unibody since you have to have things welded to the frame
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 03-14-2018, 04:43 PM   #13
Lee Valentine
Liked 319 Times in 68 Posts
Dan, with a stocker cam, more converter and gear to go with it you'll pick up guite a lot. Good luck with it. Lee
Lee Valentine 1661 STK
Old 03-14-2018, 05:04 PM   #14
Dan Fahey
Dan Fahey's Avatar
Thanks Lee
Hope so..
Right now limited to 4400 stall with the Yank 4400PT in the 4L60E
Figure 5.13 or 5.38 gears with 30 inch tires will help.
Have an 10 Bolt 8.5 inch rear.
Later can upgraded or move to 12 bolt.
Mixed opinion whether the 8.5 is strong enough.
The PCM is limited to 7000 rpm...so need a cam that is all up by 6800.
Dan
Old 03-14-2018, 05:41 PM   #15
Billy Nees
Liked 7,742 Times in 1,740 Posts
Dan
8.5 is plenty strong enough with a spool and big axles. Big question will be can you get a deep enough gearset.
Billy Nees 1188 STK, SS
Old 03-14-2018, 09:23 PM   #16
Dan Fahey
Dan Fahey's Avatar
By the time I buy the parts and have some install everything.
Might be better to by a whole new prepared rear and bolt it in.
D
Old 03-15-2018, 02:01 PM   #17
John Kissel
Liked 230 Times in 94 Posts
Hope you took care of the body mount problems as those cars are Flexable Flyers. We had a '96 SS, nice cars if you have some tools and like to use them. John Kissel K242
John Kissel is offline   Reply With Quote
Old 03-15-2018, 11:43 PM   #18
Dan Fahey
Dan Fahey's Avatar
Been part of ISSCA and WAIL groups for good while.
Added body mounts in missing areas a while ago.
Did FFAT at a Summit point couple times and some auto crossing.
Hawk pads with stock calipers did just as well as the Higly rated after market calipers.
For drag racing added a Dick Miller Suspension.
Used Belsteins shocks all around.
The fronts behaved like 70/30 for drag racing.
At ISSCA Nationals would drag race with DOT’s and auto cross putting the street BFG’s back on the car.
Up until a year and half ago would drive to the IHRA, WAIL and S/SS and Bracket Racing meets.
Put the racing tires on to drag race.
Then put the street tires on to go home or the motel.
D
