Liked 165 Times in 51 Posts
I was looking to see how much interest there would be in an SFI approved TH 200 Metric case.
I would think with all the people using them in stock & super stock, a corporation that builds this type of case would stand to make a nice profit given the new 10.99 rules? Would you buy one if it was available, instead of using a blanket or shield? I'd take one!!
Glen DeMenge 1969 Camaro Stock Eliminator |
Liked 239 Times in 114 Posts
I see ATI just released a SFI case for a 350THM . They may be a good place to ask, if there is enough interest in the 200 .
Liked 319 Times in 68 Posts
Seeing I have five th-200's I'd be good for 5.
Lee Valentine 1661 STK |
Liked 147 Times in 38 Posts
I would be interested in one
Liked 13 Times in 10 Posts
be in for 2
Liked 4 Times in 2 Posts
I'll take 2
M.Lind D/SA |
The 350 case will not be available until end of season.
Ross Gregory 5133 Stock,Super Stock 53 Top Dragster |
Liked 1,607 Times in 584 Posts
While there is not an SFI case for the T-200, if you want a stronger case, if you can find one, use the BOP T-200-4 case that was used on GM cars that were powered with the Oldsmobile 350 Diesel engine.
The bellhousing and case is way stronger and even heavier because the additional material in the case. |
I could use 2
Kevin Belisairo 589 J S/A |
Guest
Posts: n/a
The point of the SFI case is not only because it’s stronger, it is so you don’t have to purchase a blanket or shield. A different production case doesn’t solve this issue
QUOTE=SSDiv6;557372]While there is not an SFI case for the T-200, if you want a stronger case, if you can find one, use the BOP T-200-4 case that was used on GM cars that were powered with the Oldsmobile 350 Diesel engine. The bellhousing and case is way stronger and even heavier because the additional material in the case.[/QUOTE] |
