Old 02-22-2018, 12:08 PM   #11
Mark Ugrich
Liked 71 Times in 38 Posts
Default Re: Thoughts on accepted aftermarket heads for 350?
Originally Posted by Bobby Lundholm View Post
Any modifications to the runners are illegal, so if they match up to the stock numbers NHRA will know they are modified.
So if I’m understanding this correctly , you must run the aluminum/ replacement heads in either stock or super stock using the runners as they come from the manufacturer. The exception being replacing the valves and seats with the correct OEM sizes?
