#1 | |
News flash IHRA doesn't run stock anymore so how can it be a legal sticker without a sanctioning body?
James Williamson W200 J/SA. SS/JA Last edited by HR9121; 02-16-2018 at 11:23 PM. |
Liked 252 Times in 91 Posts
Are there any other differences between an NHRA Stock car and a IHRA Crate Motor Stock car, other than the engine?
Liked 62 Times in 17 Posts
Liked 138 Times in 51 Posts
You're also allowed minor suspension mods for tire clearance (i.e.: 3/4" offset kit for leaf springs on Mopars.) and you can have a trunk mounted battery without a matching one up front. There were originally a few cars built with springs moved into frame rails, but they were getting away from that as too radical. They also revised other rules shortly after inception that originaly allowed other brand rear ends (i.e: Ford 9" in place of 8 3/4" - sounds like FS!) and tightened up on hood scoop rules to keeping original hole specs & sealed/unsealed configurations, like with "regular" Stock rules. They also allowed replacement aluminum radiators before NHRA did.
LOCOMOTION Racing Last edited by Myron Piatek; 02-17-2018 at 09:11 AM. |
Liked 1,865 Times in 435 Posts
Good Luck to you 1/8 mile folks glad you have a program to race
But you proud crate motor and pure Stock racers better get of ClassRacer and race Also you Proud people fail to realize that most ihra support came from us Nhra racers If you continue to get same car counts as in the past You will have nothing again If you get less support from the Nhra car you will have No Cars. We get more cars at an East Coast Stock Ss race than you could get at any 2 ihra races All Talk Will Spell Doom for you keyboard beaters. We will see. I bet you guys fumble the ball and make excuses
james perrone 1290 STK |
#6 | |||
What % of cars, that were running Crate Motor classes recently, had taken full advantage of the rules? What % were otherwise NHRA-legal cars that just had an engine swap? If you put a NHRA-legal 9" tire on a car that still had it's IHRA-allowed mini-tubs and relocated springs, would it have an advantage over a NHRA Stocker? Is it correct that you can build certain NHRA-legal Stocker engines almost entirely out of aftermarket parts, aside from the intake manifold? (approved replacement block, oil pan, crankshaft, rods, pistons, heads, carburetor/EFI, & ignition, plus all the traditionally replaced components like headers, cam, valve covers, rocker arms etc.). |
#7 | |
Liked 3 Times in 1 Post
If you guys really want to get these cars added on a regular basis I suggest you show up and support these Open races. Rich and Division 2 have given you guys an opportunity to show there is a need. If I were in your position I would be rallying my fellow CM racers and preparing to go support these races instead of coming on here trying to pick a fight and calling people cheaters.
#9 | |
Liked 184 Times in 113 Posts
Birch did not call them cheaters. He repeated what they said! Hope all this has solidified CM racers. Maybe some enterprising soul will start a CM association. D |
Dan I'm trying to turn over a new leaf here, I don't recall anyone admitting anything about any cheating here so may be you can point that out for me. I am completely sincere when I say the ball is in their court here, if I had a crate motor I would be prepared to travel from half way across the country to attend these races to show there is support. If CM guys don't come to these races it will go away just like IHRA.
