Old 11-19-2017, 02:25 PM   #31
Bruce Fulper
Liked 54 Times in 33 Posts
Default Re: Bellhousing
I'm a dealer for McLeod and can usually beat anyone's prices. Get your part number and pm it to me. Same for Edelbrock, Comp, JE.
Bruce Fulper is offline   Reply With Quote
Old 11-26-2017, 06:58 PM   #32
Dave Toce
For those that are looking for real numbers. The old bellhousing is the standard Lakewood SBC PN 15000 (30.6 lbs). The Mcleod is the new aluminum style with the titanium insert (14.8 lbs). This is only the bellhousing and does not include the motor plate. The weight savings is 15.8 lbs.
Name:	old small.jpg
ID:	43727   Click image for larger version
Name:	new small.jpg
ID:	43728   Click image for larger version
Name:	box small.jpg
Dave Toce is offline   Reply With Quote
Old 12-08-2017, 11:20 PM   #33
Dave Toce
Warning: I just tried to install this bellhousing and it will not fit. I am using a 10" Advanced Clutches single disc clutch and the counter weights hit the inside of the bellhousing badly. What tipped me off was that the bellhousing wouldn't sit flush to the engine block. When I looked into why the problem because clear. This is a nice product but if this won't fit under my clutch assembly it will not fit under a lot of other clutches. I feel Mcleod should give a better product description to bring this to the attention of possible buyers.
Old 12-08-2017, 11:58 PM   #34
Nmbr1GMfan
Looking back at your pictures I can see why, the new one really looks like it cones down shallow right where the counter weight sticks past the clutch cover.
Todd Greene
Old 12-09-2017, 11:59 AM   #35
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Dave,
This is just a thought, have you contacted Rob yet about this issue? He may have a solution for your current clutch.
Good luck
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 12-09-2017, 01:33 PM   #36
Dave Toce
Originally Posted by Sean Marconette View Post
Dave,
Good luck
Sean
I haven't yet I am going to.
Old 12-09-2017, 02:19 PM   #37
Shadylane
Shadylane's Avatar
Liked 171 Times in 51 Posts
I ran into the same problem with a Quicktime and one of Rob's clutches. I ended up installing a 1/4" spacer plate between the bell and the plate (QuickTime RM-6013). Then I had to readjust the fork and throwout bearing clearances. After all the juggling it worked.
Shadylane is online now   Reply With Quote
Old 01-06-2018, 10:12 PM   #38
james schaechter
Liked 1,436 Times in 299 Posts
The quick time I use has a thicker block saver, so maybe that is worth a try. It is aluminum. I can fit that clutch and a dual 7. I have put a billet clutch in with the spacer. You need to make sure to realign everything and check your crossmember mount and even driveshaft length if you were close.
James Schaechter 3163 STK
Old 01-08-2018, 08:26 AM   #39
Dave Toce
This item is all set I'm on to other things now, I work quickly. I ended up using a Quciktime 1/4" thick steel midplate and adjusted the ball stud height to make up for the 1/4" extra depth.
Old 01-14-2018, 10:05 AM   #40
james schaechter
Did all of the bolt holes line up Orr did you need to re drill some on the lower half?
