Old 12-29-2017, 12:00 PM   #10
C5 Pete
C5 Pete's Avatar
Default Re: Throttle Stop w/ 1 blade TB / roll RPM Q
Question about the single blade TB.
Are you talking about a cable operated TB with a throttle stop, or using a plate under a DBW TB?
I’m trying to figure out a solution to this same problem as the OP. I’m currently using a DBW TB, but I can make the switch to cable, if it’s the only way to make it work.
Thanks for any guidance.
C5 Pete is offline   Reply With Quote
