Old 11-16-2017, 06:55 PM   #11
pfordamx
Liked 7 Times in 5 Posts
Default Re: looking for double adjustable rear shocks
Just some 90-10s this what it looks like when it hooks.
pfordamx is offline   Reply With Quote
Old 11-16-2017, 07:06 PM   #12
pintojoe II
A double adjustable front would be your best bet. Slower front extension so it doesn't top out fast then stiffer compression to stop the bounce. The viking crusader front with the DH valving will do it. I have there fronts. But like i said the backs didn't work out
pintojoe II is offline   Reply With Quote
Old 11-16-2017, 09:35 PM   #13
pintojoe II
https://www.facebook.com/joseph.boyw...99362423432232
Old 11-17-2017, 12:42 AM   #14
Ed Wright
Ed Wright's Avatar
No more violent than that Rambler is, it doesn't need anything else.
I see you are from OKC? If so, and you were at the recent NHRA points race at Noble, you would have seen my car carrying the front tires well past the 60' beams with the front shocks set very tight. I was thinking I should have brought my 60lb front ballast bar.
Most any Super Stock car making any power at all, with 90-10 front shocks, would be a hand full to drive. Wheels MUCH higher than the Rambler's.
Too high, and unloading on the wheelie bars hard can roll the sprague on the back of a T350 clutch drum, ending up with high gear only, until an expensive repair is done.
90-10 front shocks can get you by just fine on a slower car like the one in that video. 1.45 is very slow in 60'. Mine's been 1.26, and it ain't the fastest.
Ed Wright 4156 SS/JA
Old 11-17-2017, 10:12 AM   #15
pfordamx
Ed ive seen your car run a couple of times my dad grew up in sands springs and remembers several of your cars. I agree the car doesnt leave as hard as we would like either. But its getting a different engine next year and should pickup. The problem is even with an underpowered engine it would only do this about 1/2 the time the rest of the time it would brake loose right on the hit.
Old 11-17-2017, 12:01 PM   #16
pintojoe II
Frontend is topping out to fast and unloading rear tire
Old 11-17-2017, 06:50 PM   #17
Ed Wright
Ed Wright's Avatar
Not coming up too fast. Could maybe use a little more travel. Did not show the burn out. What tires? Wheel width? How much air? Should be very easy to dead hook every time.
Old 11-17-2017, 08:00 PM   #18
pintojoe II
Cool Re: looking for double adjustable rear shocks
If you say so..
Old 11-17-2017, 09:03 PM   #19
Hacksaw
Liked 309 Times in 173 Posts
In the video you present I see little wrong. Most probably you have too little extension travel on the front. Thinking your shocks are topping out before the suspension. That's a no no.
Hacksaw is online now   Reply With Quote
Old 11-17-2017, 09:08 PM   #20
Ed Wright
Ed Wright's Avatar
If you say so..
Been doing this for fifty years now, racing several different cars, never had one unload the rears because the front came up too fast. That one in the video doesn't come up all
that fast anyway.
And, I agree with Hacksaw above.
And, why "bracket radials"? Instead of regular radials like a Super Stock car runs? Mine are MT 13" X 31", on 14" wide wheels, with 13 psi. If you could spin those, you would have to be doing something seriously wrong.
The late '60s AMX factory race cars would hook on the nastiest tracks we had. Those were all "no prep" too. Nothing did wheel stands like those cars. LOL
