Liked 168 Times in 30 Posts
One other thing was changed, weight of the car.
Was at 3640, now @ 3750. Crank is internally balanced with Mallory metal. This is why I elected to have it repaired. To avoid the cost of rebalancing another crank. Rob & Main bearings have been changed every time. I am going to change out the crankshaft this time & have the line bore checked & corrected if need be. Since I'm new to this type of racing, anyone want to recommend a crank shop? |
Liked 346 Times in 126 Posts
where are you located?
Liked 68 Times in 41 Posts
Make sure the hub is not bottoming out and pulling the flex plate to the converter.I had a simlair problem.had to put washers under the converter legs to pull it out of the crank.
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
Liked 205 Times in 93 Posts
when you believe the clearance is set, I like to check the area's with a feeler gauge. just because the dial indicator says one number, the cap could still be crooked. the gauge will show if its the same everywhere..
