Liked 30 Times in 17 Posts
I don't see how the trans would have caused a rod bearing issue. What did the thrust look like at that point ? Are you using the same bearings as before ? Same clearances ? Just curious.
Bill Koustenis |
Liked 334 Times in 181 Posts
Bent crank-- trans crooked---convertor ballooning--- insufficient oil / lubrication---dowel pins not zeroed in ---- Fed387
I wiped out the thrust bearing in my 340. After a lot of thought, I determined the failure came from
stacking the weight of the engine and transmission on the driveshaft at the hit. I had eliminated the engine mounts and was utilizing an engine plate and OEM transmission mount to locate the engine. After the crank repair, I added a fore and aft limiter. I've had harder launches since then and no sign of thrust failure. The first thing to identifying the culprit is asking, "What changed?" |
Liked 168 Times in 30 Posts
One other thing was changed, weight of the car.
Was at 3640, now @ 3750. Crank is internally balanced with Mallory metal. This is why I elected to have it repaired. To avoid the cost of rebalancing another crank. Rob & Main bearings have been changed every time. I am going to change out the crankshaft this time & have the line bore checked & corrected if need be. Since I'm new to this type of racing, anyone want to recommend a crank shop? |
Liked 346 Times in 126 Posts
where are you located?
