Liked 20 Times in 15 Posts
'79 AMC 304/2 125/180- is there any advantage to boring .060 with a small(1.79) intake and 2BBL carb or will a .030 overbore be sufficient??
Liked 320 Times in 102 Posts
Well,
Just looking at an engine as an air pump..... With a +.030 overbore the displacement is 308 ci With a +.060 overbore the displacement is 314 ci With a +.080 overbore the displacement is 318 ci If you make 1 hp/ci you would gain 6 hp going to +.060 plus the additional compression..... Just my thoughts, PS: Don't forget to stroke the crankshaft for additional displacement and compression With a +.060 bore and a .013 stroke you end up with 315 ci
Bob Mulry 7516 STK A & M Motorsports Last edited by Bob Mulry; 08-28-2017 at 12:12 PM. Reason: more math |
Liked 20 Times in 14 Posts
Is there any affect of over boring if the intake cant flow any more air?
#4 | |
But shouldn't you build your combination around what you run and more cubic inches can't be a bad thing???????
yes most definitely,it was just a thought. If you went from 030 to 060 and car slowed down with no other changes could intake actually slow it down in this case?
In addition to more cubic inches, it will unshroud the valves and chamber which it is a plus for engine flow.
Thinking out loud....the extra weight of the piston is of any concern? The cylinder fills to capacity regardless of any restrictions(valve size, head design)?
#8 | |
Everything helps on a small motor, but make sure you concentrate on minimizing the deck height.
#9 | |
Liked 172 Times in 81 Posts
Jim Mantle V/SA 6632 |
