Old 08-23-2017, 07:47 PM   #1
James Perrone
Liked 1,821 Times in 425 Posts
Default Re: 66 Nova alignment
Originally Posted by Eddie Rezac View Post
Have you, or any one else, ever aligned a Chevy 2, using stock parts, and no bending arms, or relocating pivot points, etc, that has 5" up & down travel, without any toe change whatever? My kit will accomplish this! The kit is a bolt on set up, that requires no changes at all to the rest of the stock suspension, just bolt it in, adjust it as per my instructions, and go racing.
Eddie Rezac
Mmmmm I believe so only since 1983. My ss/ga.
I don't Aligment my car I have a experienced front end guy doing it
My advice is free unlike yours
james perrone 1290 STK
Old 08-24-2017, 07:04 AM   #2
Eddie Rezac
Liked 63 Times in 7 Posts
Smile Re: 66 Nova alignment
James,
I did not want to get into an argument over this subject! You are correct in stating, that any good front end tech, using stock parts, can align a 1968 & newer Chevy 2 front end, like the 1969 that you race. The 1962-67 Chevy 2, is a totally defferent ball game. Just ask anyone that races one. Having said this I will sign off now as we are not talking about the same thing.
Good luck at the race's, Eddie Rezac
Eddie Rezac is offline   Reply With Quote
Old 08-24-2017, 12:08 PM   #3
Liked 5,121 Times in 1,952 Posts
Eddie ,I believe James also owns an early Chevy II SS'er. I don't know who built it originally.
James, this is easy enough to settle. Just post a picture of your steering assembly.
We're going to assume then ,that it has stock length tie rods, center link, steering arms,and idler arms. Just a regular alignment , like you'd get at the tire store.
Eddie, you know you can have a logo posted here, as part of your sponsorship package, right?
Old 08-24-2017, 01:56 PM   #4
James Perrone
Mark no magic. Just stock front end other than qa1. Shocks. Nothing to see
From what I understand you need to check Aligment at ride hight
No expert just the nut behind the wheel. I own a 1967 nova. And a 1969
I may no something
Old 08-25-2017, 09:23 PM   #5
jaf2021
Liked 5 Times in 5 Posts
Question about bump steer?
When the front wheels come up in the air and come down and they wobble like crazy for a few seconds is this what is considered bump steer??
jaf2021 is offline   Reply With Quote
Old 08-25-2017, 10:03 PM   #6
Eddie Rezac
No, most people call that a "Death Wobble". Bump steer is the toe change that occurs when, the front wheels travel up ,& down, which in turn can cause the tires to scrub while going down the track, with even the smallest movement, of the front end action. Thus, the need to correct this so there is no change in the toe, what so ever! Just setting the toe to ride height, on a Chevy @, and many other cars will not accomplish this.The toe on a Chevy 2, can change as much as 2", in 5" of up & down travel. My kit will fix this problem.
Eddie Rezac
