Old 07-22-2017, 11:03 AM   #1
SDT1DYI
Liked 456 Times in 148 Posts
Default Hollow stem intake valves
Are hollow stem intake valves legal in stock if they were not OEM for the engine? As well is it legal to change valve stems sizes in stock but keeping the same valve angles?
SDT1DYI is offline   Reply With Quote
Old 07-22-2017, 11:26 AM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Hollow stem intake valves
In the rule book , it says "Any aftermarket steel valve permitted, must retain stock head and stem diameters" . Says nothing about hollow stems being illegal .
Old 07-22-2017, 07:30 PM   #3
It is NOT legal to change valve stem size. Not in Stock Eliminator or Super Stock.
But hollow stem valves are legal, even if not originally equipped. We run them in everything, we use Ferrea.
Old 07-22-2017, 07:48 PM   #4
ss3011
ss3011's Avatar
In Super Stock the valve stem needs to be the stock size , but aren't you allowed to use necked down stems near the valve head , like the Manley "Pro-Flo" style valves ?
Old 07-22-2017, 07:51 PM   #5
Yes, they can have an undercut stem behind the head of the valve.
Old 07-22-2017, 11:59 PM   #6
SDT1DYI
Titanium valves can not be used but are titanium retainers legal?
Old 07-23-2017, 11:10 AM   #7
Todd Gross
Liked 54 Times in 24 Posts
Section 10A says "Titanium prohibited". Although that's vague and you don't know if they're referring to valves only or all of valve train. But I know when the Drag Paks came out they had titanium retainers and were allowed one year to remove and replace with steel (I read that anyway). Everyone uses lightweight tool steel retainers for the most part.
Todd Gross
3323 FS/E,F
Todd Gross is offline   Reply With Quote
Old 07-23-2017, 03:46 PM   #8
SSDiv6
Titanium valves can be used in Super Stock classes as a replacement for OEM engines that had Sodium filled valves.
