Liked 358 Times in 83 Posts
Wondering how many Super Stock racers use bias-ply tires for most of their runs, but put on radials when they have to go as quick as possible (e.g. heads-up race during eliminations, running for class, etc.). Also, for those who do use bias-ply tires, what is your usual air pressure? Thanks very much.
Liked 443 Times in 116 Posts
We've had awesome luck with M/T tires both radial and bias ! Your spot on with bias on a every day use our truck is a GT/TC truck 327-250 short time in the 1.31-1.33 range . We run 18lbs in the radial and with the 14/32 bias 14 - 15 depending. We change the bias out because we feel guilty not performance based around 150 passes. The Mickey's have been awesome ! Hope this helps.
Marc |
Liked 431 Times in 224 Posts
IMO, radials are the baddest tires out there if you can make your car work with them.
I'm just a lowly bracket and Super Street racer, but I put 240 passes on my last set of 9" Hoosier radials.
S/ST 51 S/C 53 |
#4 | |
Liked 53 Times in 38 Posts
Liked 314 Times in 177 Posts
