Old 06-29-2017, 07:23 PM   #1
Rat Raceway
Rat Raceway's Avatar
Liked 35 Times in 17 Posts
Send a message via MSN to Rat Raceway
Default Re: Weight question?
(EDIT)So 3506 or less is good?
Ross Gregory
5133 Stock,Super Stock
53 Top Dragster
Rat Raceway is offline   Reply With Quote
Old 06-29-2017, 08:56 PM   #2
Hacksaw
Liked 309 Times in 173 Posts
Yes, there is a max weight for class racing. If your weight is more than your class than you must move to the next lower class or get bounced. Approx. 15 years ago NHRA stopping anyone from utilizing excessive amounts of ballast. The reasoning is: get a more realistic hp factor for that combo. Comp, is different, the exact rule is lost some where in between my ears, can only be within so many inches as claimed ....... I think
Old 06-29-2017, 09:10 PM   #3
FED 387
Liked 332 Times in 180 Posts
Comp is pounds per cubic inch plus whatever rule book says concerning heads/ carbs/transmission etc
Old 06-30-2017, 08:25 AM   #4
Hacksaw
You may not claim any more than 5 cubic inches of your actual engine size in Comp.
Old 06-30-2017, 01:12 PM   #5
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Go here for info
http://www.classracerinfo.com/Default.aspx
Stock Classes HP Factor: 385 Power/Weight Factor: 8.74
# index
Lightened Class A/S - 8.00 Lb/HP 3250 10.95
Natural Class B/S - 8.50 Lb/HP 3443 11.20
Weighted Class C/S - 9.00 Lb/HP 3635 11.35
Manual Transmission Classification
Bob
PS:
Thanks to Dwight this info is easily available...
Bob Mulry 7516 STK
A & M Motorsports
Old 06-30-2017, 01:59 PM   #6
Rat Raceway
I totally understand now. Thanks to everyone!
Ross Gregory
53 Top Dragster
Old 06-29-2017, 10:27 PM   #7
Liked 5,120 Times in 1,951 Posts
Originally Posted by Rat Raceway View Post
So 3539 or less is good?
No. I don't know where you got that number. Please explain.
Old 06-30-2017, 01:26 AM   #8
Rat Raceway
Sorry Mark I fat fingered my number...
3337 plus 170 for the driver is 3507 Minimum weight
So one pound off the B/S minimum 3506 and you are good to race up a class?
Ross Gregory
53 Top Dragster
Old 06-30-2017, 08:00 AM   #9
Albert Lee
Liked 258 Times in 49 Posts
A min: 8×385=3080+170=3250
B min: 8.5×385=3272 +170=3440
All weights are rounded down to the next 5 pound increment. The A max would be less than 3440.
Al Corda
Albert Lee is offline   Reply With Quote
Old 06-30-2017, 08:16 AM   #10
Liked 10,691 Times in 2,227 Posts
