#31 | |
Liked 53 Times in 38 Posts
#32 |
Liked 250 Times in 49 Posts
I don't think tech will buy a bolt in roll bar.
Pete |
#33 | |
Liked 62 Times in 17 Posts
I believe the 69 383 Barracuda is at 295 hp. That's 4-5 less than the 340. With the Edelbrocks...maybe 300? Positive deck height with no valve relief is a limitation, and no aftermarket connecting rod available anymore (Eagle has larger than stock side clearance). |
#34 |
Jim Hale ran his '67 with a 383 in G/SA and didn't too bad with it before he sold it.
#35 |
#36 |
#37 |
Liked 346 Times in 126 Posts
when did the rules change? Thi sis from the 2008 rule book
Unibody cars with stock floor and firewall (wheeltubs permitted) may attach roll bar with 6-inch x 6-inch x 0.125-inch (1/8") steel plates on top and bottom of floor bolted together with at least four 3/8-inch (0.375") diameter bolts and nuts |
#38 |
Liked 25 Times in 16 Posts
2016 Rulebook, "Unibody cars with stock floor and firewall (wheeltubs
permitted) may attach roll bar with 6-inch x 6-inch x .125-inch steel plates on top and bottom of floor bolted together with at least four 3/8-inch bolts and nuts, or weld main hoop to rocker sill area with .125-inch reinforcing plates, with plates welded completely. Also, the roll bar may be welded to frame connectors that are fully welded in place and are 1 5/8 inches x .118-inch MS or .083-inch CM round and/or 2 inch x 2 inch x .058 MS or CM rectangular."
Mopar 2 Ya! |
#39 |
Just another thing I've learned today.
#40 |
Liked 783 Times in 195 Posts
I believe that you will find, however, that all the braces and side bar must be welded to the car. I ran into that way back in 1980.
Jim Hale's current car is a 383 small valve, small carb combination - 1966 Belvedere Station Wagon.
