Old 05-31-2017, 11:34 AM   #1
SDT1DYI
Liked 453 Times in 146 Posts
Default Q Jet Secoundary Rods
Having trouble getting the secoundary's jetted properly. Have several questions regarding rod sizing and tip lengths
Smaller the final tip size, does it always mean the richer the mixture? Do the tip lengths S, M, SM and L effect rich or lean condition with the same tip final size?
Why are LL tips never to be used in greater than 70% air valve opening?
Wanting to start on the rich side, is there good rod and hanger letter numbers to start with for a SBC 350 stocker for sea level conditions?
Tension on the Air valve. What effect does the tension have in 60ft times? Is it better to be on the loose side or on the tighter side using a 2 step WOT?.
Thanks to everyone for the help .
SDT1DYI is offline   Reply With Quote
