Old 05-29-2017, 08:28 AM   #1
Alan Nyhus
Liked 799 Times in 236 Posts
Default Re: Beadlock wheels on a stocker? Why or why not?
Originally Posted by stocker396 View Post
Noticing high HP small tire cars going to beadlock type wheels but not so much in stock/super stock. Why not? The Small tire grudge guys run on radials too... Any advantage or disadvantage? Thinking on new wheels soon trying to think ahead...
Weld offers a knurled finished lip when you can't or don't want to use screws. -Al
"That'll never work....."
Old 05-29-2017, 10:29 AM   #2
Todd Geisler
Liked 345 Times in 149 Posts
Whether or not the beadlocks is needed is personal choice imo.
I've been 1.12 60' on a 275 radial and no beadlocks. Never had an issue.
I chose beadlocks so I could swap tires at home...convenience and a time saver.
I've not seen a performance difference due to the weight of beadlocks. We're talking about 4 to 5 lbs more for a double beadlocks wheel. I've changed from one tire (24 lbs each) to a different brand that was 36 lbs. No performance loss and the tire weight is at a much larger circ. than a beadlock.
Also, NEVER use run screws on a radial tire. Here is why...
Todd Geisler is offline   Reply With Quote
