Old 04-16-2017, 02:46 PM   #1
mopargilley
Liked 5 Times in 3 Posts
Default Diesel Pusher
I am looking at a 2000 Monaco Windsor 40' 1 slide 350 Cummins, and Allison trans. I tow a 24' enclosed will it have the power I need? any comments welcome. I now have a 2004 Georgetown V-10 and is pretty good for towing.
Thanks
mopargilley is offline   Reply With Quote
Old 04-16-2017, 03:55 PM   #2
Jeff Stout
Liked 704 Times in 281 Posts
Default Re: Diesel Pusher
You should be happy. My 300HP American Eagle pusher pulled 28 ft trailer and only struggled up the grapevine in CA. 8MPG
Old 04-16-2017, 05:33 PM   #3
jmcarter
jmcarter's Avatar
Liked 3,184 Times in 973 Posts
If you liked your V10 you'll love the 350 Cummins. Just make sure there isn't any open campaigns and that maintenance has been kept up to date. On long grades you may be passed by larger DP's (450-600 Cummins are becoming more common) but will keep up with heavy trucks no problem. If not a side radiator keep your eye on temps pulling an enclosed.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 04-16-2017, 06:54 PM   #4
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
my 40ft. winnebagp has a 350 cummins . no problems pulling my 30ft. tag. trailer is 12k loaded.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 04-16-2017, 09:17 PM   #5
mopargilley
Thanks all!
Old 04-28-2017, 09:41 PM   #6
mopacltd
Liked 124 Times in 44 Posts
My 275 HP Cat pulled a 26 foot trailer with a '55 Cheby to Ohio and back a couple of weeks ago. 9.7 mpg and only struggled on the LONG west bound pull into Albuquerque. Just gave it a little boost to 335 hp and increased the torque by 60 foot pounds. Really pulls the trailer better, will know after next weekends tow to Tucson if the fuel economy changes.
mopacltd is offline   Reply With Quote
