Old 04-10-2017, 11:52 AM   #11
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Default Re: 454 365
Ours made 466HP @ 5500 and 510lb-ft on armstrongs, with a cam about 15 years old. And yes, the 287 intake is f***ing horrible lol
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 04-10-2017, 02:16 PM   #12
MikeFicacci
Liked 14 Times in 1 Post
Default Re: 454 365
We made 535 in my Corvette 454/365 5 years ago with a stock block and factory crank. Tons of torque down low. A new one with all the bells and whistles should fly.
Mike Ficacci Stk 1010
MikeFicacci is offline   Reply With Quote
Old 04-10-2017, 02:59 PM   #13
Terry Cain
Terry Cain's Avatar
Liked 230 Times in 106 Posts
Default Re: 454 365
Got a very similar combo for sale if someone wants to try. 68 Corvette, 427/390 hp rated at 371 and YES, it has one of those fine intakes on it too. lol
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 04-10-2017, 03:01 PM   #14
Jim Hanig
Liked 99 Times in 49 Posts
Default Re: 454 365
This one will pretty much the same as your 5years ago.No fancy head work no 1200.0 rings, Just a good raceable engine that should run 5/8 tenths under. Mike what would a new one with all the bells and whistles cost? thanks
Old 04-10-2017, 03:45 PM   #15
MikeFicacci
Default Re: 454 365
Jim, I've been out of the game. I'm not sure what this stuff costs anymore. I'm sure a 454/365 costs the same if not more than a high-compression deal being that you have to find a good set of heads and intake as you have to use the old steel stuff with that combo. The motor was close to 700 pounds if I remember correctly.
Old 04-10-2017, 08:29 PM   #16
HP HUNTER
Liked 371 Times in 129 Posts
Default Re: 454 365
[QUOTE=Jim Hanig;531808]
Originally Posted by HP HUNTER View Post
"very good ones make 600 range "
I would open this question up to the whole forum, if you have a A/SA 1969 Nova with a 375 HP 396 stick and it runs 135 MPH @ 3470 in a 29.00 baro, How much HP does this take?
With 245 CFM @ 28 inches it would have to make in the 530s for HP corrected STP. My Buick flowed 213 CFM @ peak lift and made 474 HP, theres no way that BBC intake manifold is worse than the Buicks.[/QUOTE What buick are you talking about? The 455 is way better than the 365/454 intake.
1971 Buick 455 403 intake, I've done extensive flow testing and dyno testing with this intake bolted to my 661/149 455 heads. I've also tested the 1970 low rise BBC intake on the dyno and flow bench, this intake unmodified made 532 HP on my 9.3 compression 467 with a 228 @ .050 cam with ported peanut port heads. I feel the the BBC intake has more cross section which shows by the feet per second.
Old 04-10-2017, 08:34 PM   #17
Jim Hanig
Default Re: 454 365
[QUOTE=HP HUNTER;531873]
It may have more cross section but the Buick is bigger in volume ill bet.
