Old 03-22-2017, 11:20 PM   #11
SSDiv6
Default Re: Who's the Baddest B/SA now?
Originally Posted by Kenny Boy View Post
Here we go. I will play the fool again
Car A & B both have the same engine specs.
Car A is in a more aerodynamic, fiberglass body and weighs 315 pounds less.
Car A is late on the tree
Car A can still get there without running 1.20 under ( would you like point out how foolish that statement is? Please use numbers in your example) but chooses to hit the brakes and not take the win
If car A does go get the win, and live up to the "baddest B/SA in the country" title portrayed on itself, then worst thing is it gets a 3.5% hit. Roughly the equivalent of 12 hp. I think there was a pink car that did it right in front of it
Please show this fool how I'm wrong. Can the car not incur 3 ahfs hits before it is equal to the HP rating of the exact same engine in the other lane? I have it all wrong. I'm the one who doesn't understand how it all works.
Only a fool would think that 315 lbs, with the same engine output, should have incremental times of 0.30 sec faster. But this fool does not know anything about incremental times
Your rationale is not correct!
There is more to aerodynamics than just an assumption. A small frontal area and nose shape does not make a car instantly fast.
I would like to know where you derive or the formula that 315 pounds less in weight is an instant -0.30 seconds faster.
