Old 03-14-2017, 02:04 PM   #1
nhramnl
Liked 358 Times in 83 Posts
Default Re: Roller rocker arm and stud
I would just put on a set of Jesel shaft rockers. If you can get enough of your Stocker friends to do the same, NHRA will just make them legal, and you'll be all set.
Old 03-16-2017, 11:51 AM   #2
B Aceves
B Aceves's Avatar
Liked 7 Times in 4 Posts
I would most definitely look into a set of T&D s.
You won't be unhappy
Bob Aceves,
746 E/SA
A&M motorsports
B Aceves is offline   Reply With Quote
Old 03-16-2017, 03:25 PM   #3
Bobby Lundholm
Liked 128 Times in 50 Posts
I have Harland Sharp on my engine combo that's the same as yours.
Bobby Lundholm 3516 G/SA
Bobby Lundholm is online now   Reply With Quote
Old 03-17-2017, 12:16 AM   #4
killintime6968
Liked 91 Times in 29 Posts
I think the comp cams setup is very nice but a bit overkill on a lower hp 396. Also pretty pricey when you have buy the complete kit to get the 1/2" studs because they come with new 1/2" trunions etc. As you can buy the XD rocker arms setup for 1/2" studs already.
killintime6968 is offline   Reply With Quote
Old 03-17-2017, 07:08 AM   #5
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
The studs are available without the trunions and bearings and rebuild kit
comp 4543-16
overkill? depends upon how "square" of a lobe you are using and if one is "cheating" (who would do that) and is using a larger dia lifter to take advantage of that increased "rate"
edit..I understand Crower has a stock package out also...I have never seen that setup yet
Bill Diehl B200 C/D STK
Bill Diehl is offline   Reply With Quote
