Liked 91 Times in 29 Posts
What would be good a roller rocker arm and stud for a 396 350hp stocker. I am thinking of upgrading from the Holroyd setup.
Thanks. Bruce Cameron E/S 68 Nova 396 350hp 4spd |
#2 | |
Liked 9 Times in 8 Posts
13706-KIT 1820-16 http://www.compperformancegroupstore...Category_Code=
__________________ Bill Diehl B200 C/D STK |
Liked 358 Times in 83 Posts
I would just put on a set of Jesel shaft rockers. If you can get enough of your Stocker friends to do the same, NHRA will just make them legal, and you'll be all set.
Liked 7 Times in 4 Posts
I would most definitely look into a set of T&D s.
You won't be unhappy
Bob Aceves, 746 E/SA A&M motorsports |
Liked 125 Times in 49 Posts
I have Harland Sharp on my engine combo that's the same as yours.
Bobby Lundholm 3516 G/SA |
I think the comp cams setup is very nice but a bit overkill on a lower hp 396. Also pretty pricey when you have buy the complete kit to get the 1/2" studs because they come with new 1/2" trunions etc. As you can buy the XD rocker arms setup for 1/2" studs already.
#7 | |
comp 4543-16 overkill? depends upon how "square" of a lobe you are using and if one is "cheating" (who would do that) and is using a larger dia lifter to take advantage of that increased "rate" edit..I understand Crower has a stock package out also...I have never seen that setup yet
__________________ Bill Diehl B200 C/D STK Last edited by Bill Diehl; 03-17-2017 at 07:20 AM. |
