Old 11-23-2016, 11:59 AM   #1
Default Re: Mopar 273-4bbl Combo
Originally Posted by Rob Ayres View Post
PM sent. Call me
You should call Rob.
Old 11-23-2016, 01:20 PM   #2
James L Miller
Liked 25 Times in 16 Posts
I've known Rob for many years. He drove my old Joe Ralph Thompson AWB Plymouth when a mutual friend had it. I bought that car from Fred and I had posted photos of it and Rob saw it. He described it as a scary car with the straight front axle and regular gear box. I've never actually met Rob in person, but have exchanged e-mails for about 15 years. I had that article in a Hot Rod magazine when I was a kid. I guess the Mopar world is small enough where you get to know the other Mopar guys. Rob has a mid-1960s Impala that he's running with his son.
Mopar 2 Ya!
Old 11-23-2016, 02:32 PM   #3
larrylomascolo
Liked 66 Times in 29 Posts
I had a friend who,s dad owned a 68 dodge dart,273 4spd,hub caps,14 inch bias ply green with black vinyl roof,we would take it out after his dad went to sleep,pushing it down the road,We raced a few guys with the dart and that little screamer being bone stock was impressive,good combo but like Paul said get your wallet out
Old 11-25-2016, 02:18 PM   #4
James L Miller
Boy, everyone is telling me to get the wallet out. I think I have $40 in there or maybe a bit more. It looks like the rods and pistons might be some of the big ticket items. It looks like Melling has some 1/8" wall sleeves that would reduce a 318 stock bore (Ø3.91") down to the 273 range (Ø3.66" or so). I'm thinking using Hardblok in the wimpy 273 blocks will be a cheaper way to go. The Hardblok is about $100, sleeves are around $20-40 each, plus machining. I'll see what my machinist/engine builder wants to do, but the Hardblok looks like a less expensive way to beef up the thin cylinder walls. I wonder if the later 273 blocks had thicker cylinder walls?
Mopar 2 Ya!
Old 11-25-2016, 03:06 PM   #5
Paul Wong
Liked 419 Times in 85 Posts
delete
Paul Wong is offline   Reply With Quote
Old 11-25-2016, 03:19 PM   #6
Terry Bride
I'm slowly working on this same combination for a 66 Barracuda.
You need to keep in mind that the sleeve will need a step to retain it in the parent bore. You can't stick a 3.910" O.D. sleeve into a 3.910" bore. There will be nothing to support the sleeve. You will need a sleeve with enough oversize beyond the parent bore dia. to allow an adequate step to register against. I have not found any straight sleeve with enough wall thickness to do this. In this case, the only way to do the sleeving correctly is to get a set of flanged liners and counter bore the deck for the flange.
A custom sleeve will be an expensive investment along with some fairly substantial machining costs but in the end, you will have a block that will maintain it's bore size for many re-hones.
I will have to sonic test the 1967 273 block I have to see what it has for thickness.
In the mean time, I am saving up to purchase the pistons and maybe sleeves.
Terry Bride is offline   Reply With Quote
Old 11-25-2016, 06:53 PM   #7
James L Miller
I did catch my engine builder while he was taking a break at the beach on the east coast of Florida. He was thinking along your lines but using a 340 block and get custom sleeves with the flange as you mentioned. That would be really stout cylinder walls for a 273 size engine. He said he did that many years ago when he ran his Colt in MP with a 280 CID (3.935" bore, probably the old 2.96" stroke crank) with W2 heads. I wasn't sure how big of a step was needed at the bottom near the main webbings.
I think I will start with a 273 block with Hardblok on the first go. I don't want to spend a ton of money on this project. The idea is to run quick enough to qualify in Div. 4 divisional and national events here (don't plan on going to Indy).
Mopar 2 Ya!
Old 11-27-2016, 09:42 AM   #8
Frank Castros
Liked 2,725 Times in 961 Posts
James,
I also love the combination and wish you well with your build.
Sleeving a 340 X block would be the ultimate, but very expensive (if you can find one) Hardblock in a 273 is the way to go on a budget.
Also speak to Dean Oliver about a carburetor.
No disrespect to all who have offered their advice but Paul Wong is the guy I would consult.
