Old 11-08-2016, 10:48 PM   #1
pfordamx
Liked 7 Times in 5 Posts
Default Are leaf spring sliders legal in stock?
Rule book says factory mounting point not factory mount type. Anyone running sliders in stock?
pfordamx is offline   Reply With Quote
Old 11-09-2016, 08:15 AM   #2
Billy Nees
Liked 7,925 Times in 1,760 Posts
Default Re: Are leaf spring sliders legal in stock?
If it's "sliding" then it's not mounted.
Billy Nees 1188 STK, SS
Old 11-09-2016, 11:31 AM   #3
Neil Smedley
Liked 22 Times in 7 Posts
Throw in inconsistent reaction times as well.........
Neil Smedley is offline   Reply With Quote
Old 11-11-2016, 02:44 PM   #4
How would you control the sliding?
Probably not legal, as well.
Old 11-12-2016, 01:05 AM   #5
Everett Vassar
Liked 2 Times in 2 Posts
Rear suspension / traction aid devices...anything bolted on OK...anything welded on not OK. This may be over simplification. .or just plain wrong..but that's the way I understood it.
Everett Vassar is offline   Reply With Quote
Old 11-12-2016, 01:22 AM   #6
All true..but give us an example specifically , how this would work.
Old 11-12-2016, 01:49 AM   #7
Everett Vassar
Cal tracs OK. Slapper bars OK adjustable upper trailing arms OK..etc
Ladder bars not OK..etc
Old 11-12-2016, 12:59 PM   #8
I'm not even sure what we're talking about at this point.
Replacing the spring shackles?
Housing floaters (which won't work with the above mentioned) ?
Adjustable uppers are for 4 arm suspensions, not leaf springs.
Old 11-12-2016, 02:30 PM   #9
Crew Chief
Liked 10 Times in 6 Posts
"Must remain as produced" means stock shackles. There was never a slotted shackle factory produced on a leaf spring car.
Crew Chief is offline   Reply With Quote
Old 11-12-2016, 03:49 PM   #10
Alan Nyhus
Liked 800 Times in 237 Posts
AFCO and others make them. They bolt or are welded to the frame rail and the slots allow the rear spring eye to move forward and backward.
They are not legal replacements for shackles in Stock.
https://www.summitracing.com/parts/a...-_-afco-racing
"That'll never work....."
