building a street and strip engine and was wondering on the pros and cons on these two engines . I was told to stay away from the 400 . any comments ?
Liked 77 Times in 31 Posts
400 externally balanced,and do you see many out there,,i dont ,so that tells me enough ,,,,
Liked 15 Times in 11 Posts
There is nothing wrong with the 400, with some minor upgrades that Chevy could have done. I ran one for years in my 67 Camaro, with small valve heads and cam from a 350. The car weight was 3100 and with 4.56 gears, ran 11 flat in ugly air and low 10.70's in good fall air.
I'll add to the mix. How about a 383?
Liked 662 Times in 187 Posts
Have had a ton of 355's very reliable low maintenance motors. Roller cam Brodix track 1's and 13.5 to 1 comp 10.30's all day long in a 3400 pound camaro . Had a tunnel ram and splits on one in my 70 camaro back in the 90's ran. 9.80's at 3400 pounds ! Yiu can buy everything reasonable for one .
5664 GHI/SA 1985 CAMARO RED H/SA 1985 CAMARO BLUE I/SA |
i have some parts in stock for the 355 and the 406 but none for the 383 such as the stroker crank to fit the 350 block , i believe the rods are all 5.7
If you build a 383, you must cut the mains, of the 400 crank, to 350 size. Then you use standard pin height 350 pistons with a 400 rod. Good torque engine for the money. The 350 block seems to have better head gasket sealing. But nothing beats cubic inches.
Liked 18 Times in 10 Posts
I hate the 400 blocks have seen them crack just bolting a toque plate on. The the only block when it comes in the shop I get paid 100% up front. Pretty frail block compared to a 350 block.
Using stock 400 rods in a performance 400 build in really not the hot set up !!! Don't wast your time having some one grind an old 400 its some times a waste of money as when grinding a crank that much the oil holes do move closer to the radius. I don't recommend using a externally balanced crank in a performance build. If your building a budget build you can buy a Scat 9000 series crank for around 200.00 That will internally balance and they have one for a one piece seal block that will internally balance no problem , Scat 6.0 I-Beam rods with 7/16 bolts 300.00, Pistons Wiseco has a good deal on there Protrue series pistons and rings for about 425.00 If you can find a one piece seal block and use GM Hot cam 234/242 and buy there roller lifters as kit makes for a cheap roller cam and lifters. The Dart SHP 180 CC runner heads 64CC chambers. I have done that build many times with very good results. |
Liked 133 Times in 76 Posts
Street,strip, bracket build a 350. There is no engine better for the buck, with incredible durability. If you want to build a 400 buy an aftermarket block now...or later when you waste a lot of time and money.
#10 | |
X10000000000000 I have seen a lot of guys spend good money on bad when it comes to OEM 400 blocks !!! |
