Old 09-19-2016, 09:24 AM   #1
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 306 Times in 103 Posts
Default Re: Blueprint specs.
deck clearance can be changed from spec, IE spec shows .025'' deck clearance and .016'' thick gasket, which would be a total of .041''. so as a example you could change to .002 deck clearance and .039'' thick gasket and be .041''
As long as distance between piston and head = the spec for deck clearance and gasket thickness combined is legal,always allow .002-.003'' extra to make sure you stay on the legal side.
Mike Taylor 3601
Old 09-19-2016, 10:33 AM   #2
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: Blueprint specs.
My 327 calls for .002" tech height and a gasket thickness of .018" for a total deck with gasket of .020". We all know you would NEVER set an engine up that close. It would'nt work over 3000 rpm without clearance issues.This is nothing but a legal minimum. It's OK to have more deck height and gasket thickness than the minimum. Long ago, I built a 283 with a standard bore used block(try finding one now),and after getting the block and the assembly back from the machine shop, I trial assembled it without rings just to see what we had.We had .050"on one bank, .038"on the other, and that was without gaskets. I never remember hearing of the tech team measuring anybody's gasket thickness in a tear down situation. Anybody have their deck height checked,either?
Old 09-19-2016, 11:09 AM   #3
Rsmith38
Liked 28 Times in 15 Posts
Yes - Both NHRA and IHRA checked deck height and gasket thickness on my Jeep when I set the records - both were very professional -
Rsmith38 is offline   Reply With Quote
Old 09-19-2016, 12:51 PM   #4
Michael K
Liked 62 Times in 17 Posts
Thanks for the replies. The important thing seems to be how NHRA goes about this in a tear down. I wondered why the specifications include the gasket thickness.
Michael K is offline   Reply With Quote
Old 09-19-2016, 02:06 PM   #5
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Hi,
Just adding some info............................
Measure used and prior compressed gaskets when calculating total deck....
NHRA measures the gasket that was on the engine in the area that was compressed.........
If you measure a NEW gasket that wasn't compressed you will come up short on your desired deck height.....
Gaskets will compress a bunch.....
Just sayin',
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 09-19-2016, 05:25 PM   #6
Tom Moock
Liked 10 Times in 6 Posts
Micheal K, Stock only, they also measure on the side of the piston how far down the top ring is on the piston. Tom
Tom Moock 5704 STK
Last edited by Tom Moock; 09-19-2016 at 05:39 PM. Reason: Forgot to add stock only
Tom Moock is offline   Reply With Quote
