Old 09-16-2016, 01:48 PM   #11
goinbroke2
Liked 405 Times in 158 Posts
Default Re: 1971 Buick 455 GS F/SA G/SA Build
Originally Posted by HP HUNTER View Post
At this point I have the intake side of my head where I want it, its time to look at the exhaust side. Intake valve size is 2.005 on 315/330 HP 455. Valve job is 30/45/60 30 degree back cut on the valve.
Really? 30/45/60 30degree back cut.....so a normal 3 angle cut? Did you flow the different angles and the 45 seat with 30/60 on either side flowed the best? That's interesting and certainly not what I was expecting. Having never seen the chamber I'll assume from that, that the chamber is big enough to not shroud the valve. (or the valve is small enough to not need the help)?
How wide did you make the seat?
From what others experienced with Pontiac's mimicking sbf flow characteristics, I thought the buick would follow suit. Apparently not!
Excellent, keep it going, let's see what the exh needs!
